Hi, I need a bit of advice.
Im using a Athlon 64 3700+ CPU that is not overclocked. (2.4ghz)
The problem is when Im running a chess engine that pushes the CPU hard, the PC shuts down sometimes and then reboots itself.
I think this is because the CPU is running hot when pushed hard. I downloaded some softwear to monitor the temperatures, and found that the CPU temperature is reaching around 73C while running the chess engines. The normal CPU running temperature is between 40-45C when the CPU is not pushed hard.
There is a small fan on top of the CPU running at around 2600rpm. And a large fan on the case.
What i want to know is, will this damage my CPU running between 70-75C when its pushed hard? ...as I heard the max temp for my CPU is 70C.
, where it takes my mates Athlon 64 3200+ 5 mins to drop from 58C max when pushed to 46C (both now run at under 40C idle).
