Hey i have the spec as in siggy. (edit: cpu is the 90W G0stepping one)
This is a fairly new build so still ironing out a few things also this is my first build.... so learning loads of stuff
Anyways i done a bit of research on cpu temps i get the feeling i am getting a tad high temps. I have just resit my heatsink (one that comes with it
) with some antec silver5. I'm sure i did it ok.
I'm using a software that came with the mobo ASUS probe which monitors the temps of the kit. its averageing about 87-90c now this seems very high. Im not too sure if this is temp of all cores or each core... if its each OMG
Anyways is there a better software to maybe check this ?
What average temps should i expect, ive read about 40-50.
Btw i did the line method of applying the grease as artic silver suggest.
