Hey Guys,
I have an Antec P183 Case and an intel i7 920 with an Corsair H50 cooler.. I installed real temp to check my temps and whils idle they are around 65-72 degrees ??? I purchased IC thermal paste 24 Carrot one and applied that today and they are still running at similar temps?
The only overclocking I did to my Gigabyte EX58 UD5 motherboard is change the:
CPU CLOCK RATIO X20
BCLK FREQ TO X 190 - for a 3.80 GHZ Overclock
Disabled Turbo boost Tech
Performance Enhance to Standard
The rest is all on Auto.. didn't mess with voltages left all on auto..
On the Corsair H50 I have a 120mm Noctua Fan blowing air full speed into the radiator.. Shall I add another 120mm fan the other side blowing aire into the radiator again or shall I make one blow air in and the other to blow air out of the radiator.. will this make any difference? Also are my Overclocking settings ok or shall I change them ?
Thanks for all your help..
CPU CLOCK RATIO X20
