- 1 Feb 2009
- The Zooniverse
Hi....i'm looking to upgrade,and i'd like a little advice.
I'm currently using a Pentium D 920 2.8ghz presler in a Gigabyte GA-8I945PMF mobo from packard bell,unfortunately it has a locked bios,which prevents me from oc'ing it
i was looking to spend around a 100 pounds for a decent 775 mobo,so i could oc it to 3.0ghz,or maybe a little more
... but after a bit of research it seems i could get myself an AMD x2 3.0 ghz cpu and a new AMD mobo for a little bit extra.I know my Pentium D is a bit old,but it runs very cool with a stock fan (18c as i type this) .. so i feel i could squeeze a bit more out of it.
So should i buy a new mobo and oc my Pentium D? or would i be better off getting an AMD X2 and mobo?.. i don't want to spend anymore than 130 to 150 max.
i'm grateful for any advice.Cheers
... but after a bit of research it seems i could get myself an AMD x2 3.0 ghz cpu and a new AMD mobo for a little bit extra.I know my Pentium D is a bit old,but it runs very cool with a stock fan (18c as i type this) .. so i feel i could squeeze a bit more out of it. So should i buy a new mobo and oc my Pentium D? or would i be better off getting an AMD X2 and mobo?.. i don't want to spend anymore than 130 to 150 max.
