CPU upgrade
10 May 2024
uk
Hi all, my current build is-
i3 10100f
16 GB Corsair Ram 2666
GtX 1660 Super
My question is, would it be worth upgrading my CPU to the i5 10505
Would I see a performance improvement?
i5 10505
CPU Specifications​
Total Cores
6
Total Threads
12
Max Turbo Frequency
4.60 GHz
Intel® Turbo Boost Technology 2.0 Frequency‡
4.60 GHz
Processor Base Frequency
3.20 GHz
Cache
12 MB Intel® Smart Cache
Bus Speed
8 GT/s
TDP
65 W
I3 10100f
CPU Specifications​
Total Cores
4
Total Threads
8
Max Turbo Frequency
4.30 GHz
4.30 GHz
3.60 GHz
Cache
6 MB Intel® Smart Cache
Bus Speed
8 GT/s
TDP
65 W
You would as its got more core and frequancy but you would be better going for a I5 11600k (second hand maybe)
CPU Specifications​
Total Cores
6
Total Threads
12
Max Turbo Frequency
4.90 GHz
4.90 GHz
3.90 GHz
Cache
Bus Speed
8 GT/s
TDP
125 W
Configurable TDP-down Base Frequency
3.60 GHz
95 W
Its got more IPC, a faster boost clock, more cache and supports faster memory as long as your motherboard can support it. This would also depend on what your use case is with the cpu as well.
Thanks for the reply. My reasoning for the i5 10505 is the 65 TDP as my Power Supply is only 450W.
Your gpu uses approx 125 watts so with a 95 watt cpu your 450 should be fine as long as your not overclocking either .
i3 10100f
GtX 1660 Super
For the most part no, I suspect you wouldn't.
My reasoning is that if you're playing a game that desperately needs/wants more than 4 cores, the 1660 Super and perhaps even your RAM is going to be a bottleneck too.
That said, if the upgrade is cheap, there's no harm in it and it will help you outside of gaming and the framerate consistency in some games.
I always thought the 11600K is more than 95 watt CPU. Would my Ram be compatible with that CPU?
yes. You could upgrade to 3200mz ram but Im not sure if any gains you would get would be extra cost.
Sorry Your correct is 125 watt but configurable down to 95 watts as its unlocked. My bad.
It should be. 250 watt plus any othe rfans/drives etc in your psu should only be about 300 watts but that psu is a low quality one TBH.
I wouldn't bother and save the money for a fresh overhaul down the line. If you find a cheap, I mean very cheap 11600 then ok. If you need cores then a 10400f may be a more cost effective solution.
2666 memory runs at 1.2v. if you set it too 1.35v you can get 3000 and maybe a more out of it. Not sure it make a huge difference on this platform.
Just realised this has been said previously....
Thanks for the advice. Would having more cores on the 10400f help with game performance?
Yes it could do but its very dependant on how well threaded the game is.
EDIT Just realized the i5 11400f (65w TDP) was the budget champ at the time. Much faster than the i3 10100f in all things but its still about £70 second hand
It will be fine although you could try running it faster as the 11400f supports 3200 speed ram although i had a quick look at reviews and faster ram doesnt seem to make a big difference overall. Ram is cheap though:
My basket at OcUK:
Total: £79.98 (includes delivery: £0.00)​
My basket at OcUK:
Thanks again for your help. I might just keep my Ram for another 12 months then upgrade. The 11400f seems the best bang for buck. What will game performance be like going from 10100f?
