**** CRAZIEST PRE-ORDER SPECIAL EVER! MSI GTX 670 POWER EDITION ONLY £199.99 Inc. VAT!!!! *****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
This deal is absolutely bonkers, MSI found a stash of stock in their warehouse and we've taken it all as the price we've got is superb allowing us to go sub £200, YES I REPEAT, sub £200 for a GTX 670:-
MSI GeForce GTX 670 OC Twin Frozr Power Edition 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
Transform your gaming experience with the GeForce GTX670 Power Edition graphics card from MSI. Featuring the award-winning Twin Frozr thermal solution, innovative Military Class III component design, enhanced PWM configuration, and MSI's proprietary Afterburner overclocking suite, own the best graphics hardware with the GeForce GTX670 Power Edition from MSI.
The GTX670 Power Edition features the industry-leading Twin Frozr IV thermal design. With 8mm SuperPipes soldered to an all-copper, nickle-plated base, twin 80mm Propeller Blade fans, and a high density heat fin stack, the GTX670 Power Edition is up to 16C cooler than a competing design.
It also features Dust Removal Technology, which spins the fans in full reverse for 30 seconds at system start to minimize dust buildup and ensure optimal thermal performance. The GTX670 Power Edition also features a full-length heatsink that cover the front of the PCB, cooling and protecting critical components on the graphics card while preventing PCB flex.
The GTX670 Power Edition features a robust 6+1 phase PWM design that delivers 25% more current to the GPU versus the reference design for maximum performance and stability. This enhanced allows for better GPU Boost performance under load, and provides maximum power delivery and stability for gaming and overclocking.
MSI's Military Class III components meet a more stringent testing standard than industry-wide electronic components.
Utilizing the US DoD MIL-STD-810G testing protocol, Military Class III components are rated to run under the most strenuous conditions to meet the highest levels of performance.
These components include: Hi-C CAP -- Low profile tantalum core capacitors, more than 10 times the lifespan of traditional capacitors with 15 times less power leakage Solid State Choke (SSC) -- Pure iron core choke with high working current, designed for overclocking All-Solid CAP -- Nickle-plated cover for longer endurance, up to 10 years lifespan under full electrical loads
Features:-
- GeForce GTX670 GPU
- 1344 CUDA Cores, 1019MHz Base Clock, 1097MHz Boost Clock
- 256-bit 2GB GDDR5 RAM at 6008MHz
- Innovative GPU Boost, NVIDIA PhysX, NVIDIA 3D Surround technology
- 3-way SLI, DirectX 11.1, PCI Express 3.0>/li>
- Twin Frozr IV Thermal Solution with Dust Removal Technology
- Enhanced PWM Design for increased GPU Boost headroom
- Full overclocking and monitoring via MSI Afterburner software suite
- Military Class III component design for maximum performance and power efficiency
Specifications:-
- Core Clock: 1019MHz (GK104)
- Core Boost Clock: 1079MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1344
- Shader Clock: 1930MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 2x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£259.99] Inc. VAT
Only £199.99 inc VAT - PRE-ORDER ONLY PRICE!!!
ORDER NOW
This pricing is mental at anywhere between £50-£100 cheaper than our competitors and this is also the lowest price in the UK by miles for a GTX 670. But this is no regular GTX 670 this is a Power Edition which means it uses custom PCB with better power regulation, uprated more powerful yet quieter cooling allowing its performance to close onto GTX 680. Yet all this for sub £200, our stock is limited to 500 units which at this price we believe will sell out crazy quick.
Its a bargain, its end of month, get your wallets out, spend your monies or spank the credit card. :D :D :D
ALSO INCLUDES FREE SPLINTER CELL BLACKLIST PC GAME WORTH £29.99
I might get 1 of these to SLI, but How will the temps be for sli using this with my kfa2 oc link here. http://www.kfa2.com/GTX670_EXOC.shtml
Do you think it will be toasty ? my kfa2 is set to 1189 core and never goes over 68C
If you keep the KFA2 as the top card its airflow will be slightly compromised and it will draw warm air from card below. As such I suspect your new temperatures would increase from 68c to around 77c. Which is still perfectly safe.
Of course you could always reduce the voltage of the cards slightly to offset this and reduce cores to 1150MHz to keep everything cool and quiet. :)
Damn it I just ordered 2x MSI GTX 760 GE instead of a 2nd one of these because these cards were still £270. And now selling my GTX 670 PE will be even harder :).
Tempted to cancel... and get 2nd one of these.
Damn, I dont think my 600w OCZ PSU will handle SLI which would mean me having to buy another PSU for £80 more. So not worth it to me. Bargain for a lot of people though.
Well I changed my order (thanks to super speedy 5UB :)) to get a 2nd one of these instead of 2 x 760s. Hope it is as good as my current one that boosts to 1241 Mhz :).
Now THAT's actually worth considering over the 7950 for a change...as it a) actually has a price advantage (igoring the free games), b) with a proper full size PCB and custom cooler (not one of those reference card with small PCB and mojo extension coolers) and c) 256-bit card at sub £200 price point, not over £300 as it should be.
Yeah. I'm thinking about this now (I've sold my 7970) to cover me until I upgrade properly. The resale value should still be pretty good in 3-4 months. Hmmm....
Lower prices on NV cards has definitely been the highlight of the 700 series' existence. Would be tempted to get this for bro's system but he only has a Q6600...
How they lost a stash of stock in their warehouse?? :D
It happens a lot, a manufacturer thinks they have cleared stocks worldwide, then all of a sudden one of their warehouse's made a stock error and a few cards appear. As these are EOL cards they get offered at a bargain price and I was all over it like a coiled spring. :D
It might handle it ok. Whats the rest of your spec? Im running stock speed wf 670's in sli with the cpu in sig, power draw at the wall in games is shown as 430w, (total system incl 24" monitor).
Hm bugger. Bought a 660ti amp extreme edition for £160 with metro and splinter cell a week ago. I didn't think that would be beaten but now I kind of wish I had got this....
I only want a stop gap card though as everything will be obsolete once the new consoles get in their stride and Maxwell e.t.c gets released.
