**** CRAZIEST PRE-ORDER SPECIAL EVER! MSI GTX 670 POWER EDITION ONLY £199.99 Inc. VAT!!!! *****
Everywhere is very wrong then. The 660 isn't remotely close to a 7970.
I was just looking at results of the MSI 670 OC with other GPU's, it seemed to be on par with a normal 7970 in nearly every game. MSI GTX 670 OC is priced higher than a 7870 everywhere as well, so confused!
Oh, you said 660. But comparisons with an overclocked 670 against a reference 7970 on reference drivers isn't going to be very accurate to reality. On recent drivers the 670 cannot match a 7970 at all. It's generally about 10% ahead of a 7870, trades places with a 7950.
Sorry I meant 670. I was asking which is better out of MSI GTX 670 OC and the XFX Radeon 7870 Tahiti LE.
I have the XFX but now I want the MSI as it seems have better reviews.
Your 7870 LE is really a slightly cut down 7950, it's not a 7870 at all. The 670 would only be a tiny bit faster, and not at all in some games.
If you read some reviews on 770's they have 7870 and 7950 and 670 game fps in there. The 670 is 5% to 30% faster than a 7870 in most games for only £30 more.
I got a modded cooler on my 480, but just been looking not much
better than a GTX760 at the same price!!! :eek:
Not worth it IMO!! ;)
Stock 670's are better than 760's.
And this is basically MSI's best edition of the 670 (it's almost as powerful as a stock 680).
For less than a 760.
Totally worth.
p.s. the automatic nvidia overclocking on these cards is heavily dependent on card temperature, and this card has some really sick cooling.
Is the PCB a 680 reference design?
Its a custom design using MSI very best components. One of the best if not the best 670's on the market, as such the prices makes it a crazy deal for what is one if not the best 670's ever made. :)
Interesting Facts re this card. Pulled from a review.
The Power Edition graphics card series from MSI is a relatively new addition to its lineup. The Power Edition often mimics that of the higher-end Lightning series, but at a far lower price (and perhaps a smaller feature set). This allows MSI to split the difference between the reference class boards and the high end Lightning GPUs.
Doing this allows users a greater variety of products to choose from, and to better tailor users' purchases by their needs and financial means. Not everyone wants to pay $600 for a GTX 680 Lightning, but what if someone was able to get similar cooling, quality, and overclocking potential for a much lower price? This is what MSI has done with one of its latest Power Edition cards.
The GTX 670 Power Edition
The NVIDIA GTX 670 cards have received accolades throughout the review press. It is a great combination of performance, power consumption, heat production, and price. It certainly caused AMD a great amount of alarm, and it hurriedly cut prices on the HD 7900 series of cards in response. The GTX 670 is a slightly cut-down version of the full GTX 680, and it runs very close to the clock speed of its bigger brother. In fact, other than texture and stream unit count, the cards are nearly identical.
The GTX 670 is, in fact, comprised of 1344 CUDA cores (down from the 680’s 1536) and 112 Texture units (down from 120). ROP count stays at 32 and the 2GB of memory on the 256-bit bus runs at a blistering 1.5 GHz (6 GHz effective). For essentially $100 less than a GTX 680, a user will receive about 90% of the performance (depending on the title) of the full blown GTX 680. These cards were released some months after the initial GTX 680, and demand for them has been impressive. With this demand we are now seeing more aggressive designs based on the GTX 670.
The GTX 670 Power Edition is an interesting beast. Unlike some of the earlier Power Editions, which featured de-tuned designs still based on the Lightning boards, this looks to be a slightly modified reference design. It has a slightly beefier power delivery system which takes the draw from around 100 amps to 125 amps max. TDP is listed as 200 watts, but through the use of overclocking and tweaking it can get closer to the 225 watts delivered by the dual 6 pin PCI-E power connections.
Twin Frozr IV cooling technology is used with this board, and it looks nearly identical to the Lightning and HAWK series using TF-IV. One major difference is that the card uses 80 mm fans rather than the larger 100 mm units on the top end Lightning series. This will slightly diminish cooling performance, but when we consider the conservative 200 watts TDP of the part, it is certainly not holding the design back. The actual heatsink itself is large and cools the board and chip quite effectively.
The video outputs are very nice here compared to some of the latest AMD cards. It features dual link DVI (one DVI-I and the other DVI-D), DisplayPort, and HDMI outputs. AMD’s latest cards only feature a single dual-link DVI port on its boards, which is problematic for users wanting to run non-DisplayPort enabled monitors over 1920x1200 resolutions. Those inexpensive Korean 27” IPS (which we recently reviewed) monitors which only have DVI inputs certainly come to mind. If a user wants to go with a three monitor Surround setup, then they will need to limit themselves to 1920x1200 with a $25 active DP to DVI adapter, or purchase the $100 powered active DP to dual link DVI adapter above 1920x1200.
The card is manufactured using the Military Class III components that MSI has made somewhat famous. These are higher quality hi-c caps, poly caps, and chokes. The choice of components should insure that they last longer, and have slightly higher capabilities which should help improve any overclocking ability. The combination of higher specification components combined with a slightly more robust power delivery system–topped off with an above average cooling solution–should make this a highly overclockable board.
MSI has added another wrinkle to this equation. NVIDIA previously did not allow or support over-volting the GPU and its components with its GTX 600 series of cards. With the PE and the latest version of the MSI Afterburner 2.3 software, users can, in fact, increase the voltage on the GTX 670. This should allow for some higher overclocking of what was previously still a pretty good part. With the non-voltage way of overclocking still working well for many users, this extra feature should give some nice numbers for those really wishing to push their card.
The card itself is overclocked right out of the box already. A standard GTX 670 has a base clock of 915 MHz and a boost clock up to 980 MHz. In the vast majority of applications, the clock would stay pretty steady at 980 MHz. By adjusting the power range of the card so it can pull more watts, these cards could easily hit GTX 680+ speeds. In this particular case, MSI was pretty aggressive off the bat. The GTX 670 PE has a base clock of 1019 MHz (GTX 680's base is 1006) with a max boost of 1079 (the GTX 680 features upwards of 1056 officially). This is a meaningful jump from the base clocks featured on a reference GTX 670.
These things add up to what looks like a pretty nifty part. The best thing about it is the price. The GTX 670 Power Edition is not all that much more expensive than a standard GTX 670. It retails for around $429 US, but carries a $25 MIR. This brings it perilously close to the $399 MSRP of a reference GTX 670.
I liked this card. I really enjoyed playing with a GTX 600 part for the first time. It was good that it was as fast as it was, and the extra features that the 600 series brings is really nice. Overclocking is amazingly easy, and it is pretty quick and painless to get out of an overclock that was too aggressive. The only downside I see is perhaps a lack of performance in a couple of titles as compared to the much cheaper competition. If a person were to play 3D Mark 2011 all day, then the GTX 670 is for them. In real world gaming, the differences are usually not so extreme. Only when we get to titles like DiRT Showdown or Battlefield 3 do we see some real distance between the R7950 and the GTX 670.
Through no fault of its own, MSI is sorta stuck at the plus $400 price point with this card. NVIDIA should probably lower prices on the GTX 670 to more adequately match what the competition offers at around $60 less. We also must be aware that a new 600 family member is about to be released, and that particular price point might make the current GTX 670 somewhat unattractive.
Overall this is a great card at a competitive price when looking at only other GTX 670 products. When we start to include the latest HD 7970 and HD 7950 price cuts, the GTX 670 PE starts to lose some of its luster. Still, for die-hard NVIDIA fans this is going to be a great card for them. Most other consumers will really want to weigh overall performance in the games they tend to play vs. that of overall price. Gamers looking for Surround gaming solutions will really want to take a look at cards featuring 3 GB to 4 GB of memory onboard.
MSI has produced a really good card at a very competitive price in the GTX 670 market. It has enough features to really pull it ahead of the crowd at those prices, and the performance it brings is really outstanding in a wide variety of applications (except when it falls down in DiRT Showdown). Keep a close eye on this one, as it could be quite popular at retail. Also keep a close look at prices, as some new surprises are on the way.
Not kidding there! Really interesting re the overclocking potential. This card is not for me, because I already have a 7950, if I didn't though I'd be all over it! :D
hm, very tempted to sell the 660ti amp extreme edition i just bought and order one of these...
These are basically giving stock 680 performance out of the box right?
Will all the stock come in on Monday? i.e. if i order now, will i get one by Tuesday?
