GB Windforce are not silent though once you hit over 60% fan rpm noise its way more than stock HSF & very noticeable unless you game with headphones on all the time.
I RMA'd one 3 months ago due to the noise
This should give you an idea as it compares the MSi lightning cooler, Windforce, and EVGA ACX cooler all running a 770. Have a look at the load noise levels:
http://www.anandtech.com/show/7392/the-geforce-gtx-770-roundup-evga-gigabyte-and-msi-compared/6
Yeah I was just as shocked as you when it cost just under £500 a few months ago I expected a premium HSF solution which was 100% silentI had the same problems with three of mine, I ended up RMAing them all. In fact I preferred/ended up going with a Titan cooler card over any of the custom solutions, as that just gave out a gentle whoosh.
Its as silent as the stock Ti HSF until the fan hits 60% then whhhoossshhhh still worth buying for the new price just do not expect complete silence once you load the GPU up it gets super noisy unless your case has a lot of fans I only had 6 in mine it was nowhere near enough.I am really surprised you say that. I just run my 780 at the stock boost and it is really quiet in my opinion. In fact I saw a review of all the graphics cards coolers on bitech or anandtech and the Windforce scored as one of the quietest. All the case fans in my seup run at 5v and I have a gelid tranquilo as a CPU cooler, so I should really hear a noisy graphics card.
Windforce design dumps hot air into the case the fans IMO are very poor way too small & generate too much noise under heavy GPU loadings above 60% fan RPM. GTX 970 is probably a better deal unless your not bothered about noise/heat in the case.So was it a one off or does windforce not compare well to asus and msi cooling solutions?
wondering whether a 3GB 780ti at £350 is considerable over a 4GB 970 @ £300 for 1080p gaming (and i would buy the bundled game saving another £30)
For the low price the GTX 780 Ti is a bargin as its still the joint best single GPU Nvidia card I just would be aware if your sensitive to noise/heat from your case.
Nvidia reference design has a giant Heatsink which expels most of the hot air out the back on the case!i am sensitive to noise. and i probably wont have more than 5 case fans (Cosmos II). But dont all of these coolers push hot air into the case? Isnt Any cooler that can push that much cooling air through the backplate of 2 pci slots (most of which used by display port/dvi ports) is going to be noisier than a cooler that puts hot air into the case to be expelled by the cases' 140/200mm fans etc? Or should i be looking for a reference blower fan design for maximum quietness.
Hey chaps.
Apologies since this has probably been asked before, but how long would you wait to get a 780ti since they appear to be coming to the end?
Basically I already have a 780ti with the intention of getting a second for SLI.
I want a new one, but would prefer a EVGA since I have one already and their support is excellent.
Thanks.
Thanks Gregster.
Would rather get it from here, but they haven't got any
Any chance they will get some more, or should I start hunting somewhere else.
