badbob said:What exactly is crossfire? Got a link? I understand "special" in some way and you need mobo and gfx to be crossfire.
LoadsaMoney said:If your getting the x1800 XT, then your going to have buy both the slave, and mastercards now, as x1800's have ceased production, once the ones that are out there are gone, then thats it, so if your updating soon, then chances are they will probaby be all gone by then, so unless your going to do the full upgrade now, and buy both cards/mobo/cpu etc... then your going to be out of luck, id go for the x1900, will last ages as a single card, then you can Crossfire it at a later date.
Do not go Crossfire on the x800 range, it is worthless, can't go higher than 1600x1200, and is stuck at 60hz, so it is totally pointless as there is no benefit.
LoadsaMoney said:Yeah i would think in 2x months time the x1800's would be gone, the x1900's may come down a bit by then, the x1800's have dropped a fair bit, and they've only been out just over 2x months.![]()
^Garf*uk* said:so guys think i will see a big diff from the rig i have now to what i want 2 get?
getting amd64 3700+ soc 939
dunno what mobo?maybe a lanparty one.
btw i have 2 gig in my rig now with a sata 80 gig hd![]()
thanks ppl
