Crossfire Fan Control Problem (2 X 5770s)
8 Dec 2004
Hampshire
So I started to hear a low murmur sound coming from my case. Cracked it open and I discovered a totally different problem.
Fan control is not affecting my second crossfire card.
I recently updated to the latest Cats. Any ideas what could be going on?
I take it you mean CCC fan control. Works ok for me, sorry cant help, try 10.3a cats.:)
Well heres the thing.
I have the MSI Afterburner software installed, but I uninstalled it afterwards and tried to alter the fan speed from CCC and the same issue happens.
Now I know it was working with older cats, but for some reason now... the fan speed controller doesnt alter the second 5770 fan speed.
I could try the new Cats I suppose as the post above me suggests (cheers for that!). But any other ideas?
Yes rolypoly, otherwise I would not be able to hear the fan go bezerk when I set it to 100%.
It is truly bizzare I must say.
geoiry - Im sure it is, but I dont think its a problem with the software, either its hardware/bios or perhaps the driver? Not sure!
This is my original post.
I.e. fan control DOES work, it alters one fan but not the other.
Ok mate, trying to help here. I refer to my earlier post, re ticking the boxes, which is why I wondered if you have ticked a box for each card and that you are not thinking one slider controls both cards.:)
