- 23 Feb 2011
Hi all,
I'm trying to run my 3 projectors off 2 hd 6970's but I'm having a few issues. I've connected one up through an active mini Display port to DVI cable, and the others to HDMI. When I enable cross fire X in my CCC (version 11.2), I can only pick up the one projector connected to the upper graphics card. When I untick cross fire x, then I can see all 3 projectors. Am I doing something wrong?
Also for some reason the other two projectors which are only connected through THE DVI ports display a very poor picture with lots of green lines across it.
Any help is much appreciated!
as i said possible to use some straight dvi cables? also do the projectors do the same if say you only have one plugged into a dvi slot (just one connected) ?
