Having completed both Crysis and Crysis Warhead at DX10 1920x1200 with 2x AA on the max settings of both games, I became convinced that Warhead looks worse for some reason, so I decided to test both games.
Left FPS counters on to compare performance but thats useless because no scenes match and I was also getting low FPS because of constant changing, loading etc. (Although Crysis does have a better FPS in each one...
What do you think?
Crysis:
Warhead:
Crysis:
Warhead:
Crysis:
Warhead:
Crysis:
Warhead:
The main thing these don't show is long scale scenes, Warhead has a much lower object draw distance. When I look at the screenshots both games look similar but they look quite different while playing.
)What do you think?
Crysis:
Warhead:
Crysis:
Warhead:
Crysis:
Warhead:
Crysis:
Warhead:
its worse graphically wise but not that massive.
