And just got a few questions:
First off i was worried when i looked at CPU (i5 3750k) as it had no pins
but that was me being nab.
1. Solved
2. The little rubber circles, i assumed they were for sticking on the Motherboard mount points? have i been an idiot and they're supposed to go elsewhere? i couldnt see it said, they came with the 600T.
3. SSD doesn't fit on screw holes on harddrive cages because of the 'screws' which pop on normal HDDs, am i missing something? i get some velcro tomorrow so i will propably stick to to back of mobo tray but for tonight...?
4. I kind of messed up cpu cooler installation, my k2 comes tomorrow, i have some arctic silver 5 (i think) but the pre applied paste on the intel stock cooler got a little smudged as i applied the cooler, will it matter for one day? (i dont have tim remover to reapply until tomorrow), stock volts/clocks for at least a few days.
5.... well 5 will no doubt come
ill post some pics later, its nothing amazing by these forums standard but its my first build so im happy. Just got to stick in the 670 + do some cabling (which i will probably be OCD about)
Thanks guys
but that was me being nab.1. Solved
ill post some pics later, its nothing amazing by these forums standard but its my first build so im happy. Just got to stick in the 670 + do some cabling (which i will probably be OCD about)Thanks guys
