youll probably being to hard on your self, that and you probably arnt taking your time
just dive in and give it a shot you have nothing to loose but bordam
ok this morning i was bored so i re designed the full front of my pc, i know i know its a bit late but i cant help my self and the other one just seem a bit blanned.
now i understand how case designers find it hard to come up with unique and likable designs.
heres a quick sneak peak of the sort of look im going for now, theres still a load of detail that will make this look a lot more attractive.
i started making the side trims for the face from the scrap i had from the window cut out, i told you it would come in handy lol!
i really am sick of filing must be some machine out there that can do it for you
heres the left and right done and paired, only niggle is i have the brush on them going a differant direction to the front panel, shouldnt be a problem but its still annoying.
sorry for the gap but have had a busy few days, the plasterers have been in to take care of my bedroom ceiling before i was sleeping with it in my bed
heres some pics of the job they done.
not bad just need to wait for it to dry and then im sorted, so that means work can start back on the mod just what i like to hear.
I wanted to get into constructing the face plate and making sure all my measurements were correct and see how this thing was gonna take shape
this is what i got
As you can see i couldn't find a way to mount all the pieces without hiding the rivets so i went rite to the other end of the scale and put them rite in plane sight, i think its looking good allot better than i thought they would look.
and hear i fitted the top piece that will join to the top struts
starting to realy take shape im getting excited now
