I did reduce air resistance.squiffy said:Why should the warranty be void? I have done nothing to the card itself. It's like saying fitting car speakers into the parcel shelf (cutting holes) will invalidate a car's warranty. Of course it won't. It's not like I cut the card in two. Anyway you could say any non standard CPU or videocard, chipset cooler voids your warranty. Anyway if it does fail I would dispute that, or get another backplate.
"Madness" is a bit much..![]()
Updated pic. Dunno if it's me but could be a bit quieter.I did reduce air resistance.
Er, yes you could say that. Because it does.squiffy said:Anyway you could say any non standard CPU or videocard, chipset cooler voids your warranty.
