No you're not. Read the highway code, it applies to cyclists too.
No there are different guidlines, unless your causing a hazard its not a problem.
64
You MUST NOT cycle on a pavement.
I like the way they cycle three abreast chatting to their mates while holding up traffic behind.
Indeed. Annoying. I'm sure someone will pop in here shortly claiming they're entitled to do so, too.
Thats against the HWC too, but your right it prob won't stop people saying its ok![]()
Indeed, it is against the HWC.
It wont hold you up any more than a single cyclist though because they will still be no wider than a car.
It shouldnt make a difference though, you should be on the other side of the road when overtaking anyway.
Because you obviously have more right to be on the road than the 'pro' cyclist? Road bikes aren't designed to go off-road (as the name suggests!) so that's why they're on the road! Funnily enough, cycling is also very good for you, keeps you fit and is an enjoyable way of getting around.
I always think that every car driver should be made to ride a bike on the road at some point - it would probably make them think twice about when they "think" it's safe to overtake. Most drivers have no idea how scary it can be when they come steaming around a 'rural bend at a safe speed' in their 2 tonne metal box, almost clipping the cyclist as they come past.
These 'pro' cyclists as you call them are probably more likely to obey the rules of the road than your average Joe in his 2 tonne metal box. It's the non-'pro' cyclists that give everyone else a bad name.
/rant
(if you hadn't already already guessed, I'm one of those that you class as a 'pro' cyclist)
annoying people in leotards weaving side to side with their arse in the air.
You're making yourself sound stupid. I suggest you read the highway code.
I suggest you read up more on the subject your talking about, but seem to know little about.
What you have quoted is just the guidelines for FPNs. It's still illegal to ride on the pavement, but it's at the officer's discretion to issue an FPN or not.
Can someone explain what a 'pro' cyclist is?.
I would assume that this term would refer to individuals riding on the roads such as Bradley Wiggins, Alberto Contador, Cadel Evans et al?.
