Hi all where can i buy DDR2 1333+ memory modules?
The new Gigabyte Mobo i just got says the following :
"DDR2 1333+ is supported with combination of AM3 processors and qualified memory modules"
and does that mean i would need to use DDR2 1333+ befor i can use a 6 core CPU , ..
Ill post the Mobo specs
LINK >> Motherboard
- Support for AM3/ AM2+/ AM2 processors
- Hyper Transport Bus 5200/2000 MT/s
- Chipset North Bridge: AMD 770
- South Bridge: AMD SB700
- Memory 4 x 1.8V DDR2 DIMM sockets supporting up to 16 GB of system memory (Note 1)
- Dual channel memory architecture
- Support for DDR2 1200(Note 2)/1066/800/667 MHz memory modules
- Support ECC memory (Note 3)
- Audio Realtek ALC888 codec
- High Definition Audio
- 2/4/5.1/7.1-channel
- Support for S/PDIF In/Out
- Support for CD In
- LAN Realtek 8111C chip (10/100/1000 Mbit)
- Expansion Slots 1 x PCI Express x16 slot, running at x16 (PCIE_16) (The PCI Express x16 slot conforms to PCI Express 2.0 standard.)
- 4 x PCI Express x1 slots
- 2 x PCI slots
- Storage Interface South Bridge:
- 1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
- 6 x SATA 3Gb/s connectors (SATAII0, SATAII1, SATAII2, SATAII3) supporting up to - 4 SATA 3Gb/s devices
- Support for SATA RAID 0, RAID 1 and RAID 0+1
- iTE IT8720 chip:
- 1 x floppy disk drive connector supporting up to 1 floppy disk drive
- IEEE 1394 T.I. TSB43AB23 chip
- Up to 3 IEEE 1394a ports (2 on the back panel, 1 via the IEEE 1394a bracket connected to the internal IEEE 1394a headers)
I have the Rev 2.0 version , and with a bios update i can use the 6 core chips.
LINK >> GA-MA770-UD3
Thanks in advance for your time.
Regards
Tab
LINK >> Motherboard
- Support for CD In
- 2 x PCI slots
- iTE IT8720 chip:
Regards
Tab
