- 9 Nov 2005
- Southampton, hopefully not too hot, or too cold
Is the tank ~24C because you have a heater keeping that warm?
What happens if you lower the thermostat to 20C?
Bare in mind heater thermostats are very crude and not calibrated, in my collection of heaters I have some that when set at 20C will try and maintain 25C and others set at 32C can only maintain ~25C.
Otos are very social fish, they live in 1000+ groups in the wild, if you get them you should be looking at 6+ but ideally 10+. Check out PlanetCatfish to read about the various species in the hobby.
Your WCMM may well "appear happy" at 24C, they will be hyperactive and depending upon age may try and breed. Keeping them that warm all year round will knock chunks off their lifespan, these fish can cope with a very gradual cooling to ~5C and would be perfectly fine with an average temp of ~15C. Most fishkeepers can put this species in an unheated tank without issues.
Your "Hong Kong Plec" comes from a very specialist environment, with a lot of water current and loads of surface rippling that keep the oxygen levels well above 8mg/l, these "hillstream loaches" have evolved to live in conditions similar to you having ~6000lph of water movement in your 200l (note this would be overkill for your WCMM
). You should be aiming for ~2500lph in your 200l as a compromise
Fish like these are thrive in tank setups far from "run of the mill," just like Chaetostoma spp. (Rubbernose Plecs) and the many fish that come from the Malebo Pool area of the Congo River like Steatocranus spp.; Synodontis brichardi; Euchilichthys spp. etc.
). You should be aiming for ~2500lph in your 200l as a compromise Fish like these are thrive in tank setups far from "run of the mill," just like Chaetostoma spp. (Rubbernose Plecs) and the many fish that come from the Malebo Pool area of the Congo River like Steatocranus spp.; Synodontis brichardi; Euchilichthys spp. etc.
after a couple of hours they look much more colourful than they did in the shop and when I first put them in.
