Deep End - First time Watercooling and Modding (600T)
Hello everybody! After seeing all the fantastic work on here I thought I would start a project log of my very own!
TLDR
This is my first proper computer and my first attempt at overclocking, watercooling and modding so lets rock!
Long Version
Well this is my introduction I guess. About a year ago my laptop died and I decided to build my first gaming PC. It’s evolved pretty quickly and in about November I settled on some hardware that I was pretty happy with:
• Intel i7-2600k
• Asus P8P67 Pro
• 8GB Corsair XMS3 RAM
• KFA2 GTX580 1.5GB
• Asus Xonar D2X
• LG BH10LS30 BDRW
• Crucial C300 64GB
• WD Caviar Green 1TB
• Coolermaster Silent Pro Gold 700W
• Corsair 600T Graphite
I’m pretty happy that this is a pretty solid PC for both gaming and my Uni work. Should see me through until I finish my course or I get bored! I initially started with everything air cooled and life was good.
I then started an awesome job which opened my eyes to what was possible, however I didn’t know anything about watercooling or overclocking so this was jump in at the deep end!
So let’s throw some ideas out there. The 600T has room for a slim 240mm rad in the roof and a 200mm fan in the front which is perfect for a 200mm rad. I really liked the XSPC dual bay res/pump combo and it seemed a great space saver. Last of the main parts I’ll be using are the EK waterblocks in nickel/plexi as in my personal opinion nothing else on the market looks better and the performance isn’t too bad to boot! So now I have a kit list for my cooling.
• EK Supreme HF
• EK VGA Supreme
• XSPC X2O 750 dual bay pump resevoir
• Hardware Labs Black Ice 240 Radiator
• Phobya Extreme 200mm Radiator
• 3x Scythe Gentle Typhoon 1850rpm
• A suitable fan for the phobia rad
• Aquacomputer Aquareo 5 LT
• EK Fittings all round
• Mastakleer Hi-Flex Tubing
And 30 seconds in paint to put my plan in a picture!
Well the plan is as above. I also have to say that I have started playing around and I found out a couple of things. The fans make noise as they draw air through the grills on the case and thus starts my adventure into case modding.
I marked up the holes I wanted for the fan, I guess starting my dremel experience with circles may not have been the greatest idea but it turned out pretty well for a first attempt!
Obligatory sparks photo
One down
and two down
I didnt like the points in the middle so I squared those off too.
I then ran into a problem, my last cutting disk. I guess the front grill will have to wait!
I guess that's all there is so far folks. My plan is just to make this PC as sleek and as powerful as possible so stay tuned!
TLDR
Long Version
• Intel i7-2600k
• Asus P8P67 Pro
• KFA2 GTX580 1.5GB
• Asus Xonar D2X
• LG BH10LS30 BDRW
• Crucial C300 64GB
• EK Supreme HF
• EK VGA Supreme
One down
and two down
