Delayed write failed!!
GTO
GTO
18 Aug 2006
Staffordshire
Just a quick question.
Could a lack of sufficient power cause delayed write failures?
I was having this problem some time ago on a SATA drive so, thinking it was fubared I bought a new one and all was well (for a while) then it reared it's ugly head again.
The reason I suspect the lack of juice is because this problem only started after I installed a Radeon 9800 which needs to be connected to a power supply.
AMD 64 x2 3800
ABIT AV8 3rd Eye
400 watt PSU
2 SATA drives
1 IDE drive
2 DVD drives
Any ideas or suggestions welcome.
400W of what psu? That makes a big difference! However it could well be a power issue since it happened after you put a fairly beefy card there.
To be honest I can't remember what make it is but I know it's nothing fancy.
After buying the Radeon I thought it best to get a bigger power supply and thought any 400w would do.
Maybe not?
400W is enough, i've run way harder stuff on less power, but generic psus etc.. might just not cut it, brands like PCP&C , Enermax, FSP, Antec etc.. are known to be good uns, generics may lack the power on certain rails that you need or just flat out lie about their handling power, thats why i wanted to know the brand :)
Fingers crossed my new 550W should sort things out.
I guess only time will tell.
