Dell Alienware 34'' IPS 3440x1440 100Hz Native (120hz OC) 21:9 Monitor with G-SYNC
20 Dec 2006
** Do Not Hotlink images **
https://i.dell.com/sites/imageconte...s-alienware-34-monitor-aw3418dw-module-01.jpg
Tricked out and all in
Introducing all-new Alienware monitors, mice and keyboards featuring the iconic design you trust for exhilarating, immersive gaming. Whether you're just starting your collection, or rounding out your arsenal, Alienware accessories are built to enhance your gaming experience as you journey deeper into the game.
https://i.dell.com/sites/imageconte...s-alienware-34-monitor-aw3418dw-module-02.jpg
Iconic design is in our blood.
Looks that kill: A premium, polished silver finish and ultramodern design reflect our commitment to sophisticated appearance, unparalleled quality and gargantuan gaming.
We focused on the details so you can focus on the screen: Your monitor features an ultrathin 3-sided bezel for an expansive 34-inch screen space. Our unique step-venting details help dissipate heat and maximize performance. And we added the unearthly glow of Triad lighting to complete the monitor that’s better looking than it has to be.
Curve your enthusiasm: Completely immerse yourself with a sweeping, 1900R curved infinity display that takes you deeper into the game and a 21:9 aspect ratio that makes every vantage point epic. The curved screen maximizes your field of vision, reducing eye movement, so you can stay comfortably focused on the game longer.
https://i.dell.com/is/image/DellCon...itor-aw3418dw-module-pdp-03.jpg?fmt=png-alpha
The competition can eat your dust.
Expand your horizons: In-plane switching panels mean a wide 178°/178° viewing angle from any vantage point and incredibly vivid, detailed sRGB99% color reproduction from wherever you are in the room.
Get real: A 3440 X 1440 WQHD resolution display delivers sharp, crystal-clear graphics with 3.68 million pixels—1.77 times more detail than a Full HD display. So you’ll see every blade of grass, every glint of steel, every drop of sweat more vividly, intensely and richly than ever before.
Synched up and ready to roll: NVIDIA® G-SYNC™ technology displays full frames only when the monitor is ready to display them. This means your screen frames load so fast, you can say goodbye to distortions—like tearing and artifacts—and get used to smooth, vibrant images.
By the time this sentence is over: Refresh rates so fast you won’t have time to worry about lag. Bring on even faster responsiveness with 100Hz native [or up to 120Hz overclocked] refresh rates and 4ms response times to max out on the highest, fastest level gameplay that looks and feels super smooth.
Your central battle system.
https://i.dell.com/is/image/DellCon...tor-aw3418dw-module-pdp-04a.jpg?fmt=png-alpha
Designed to beat the competition.
An on-screen display (OSD) gives you a competitive gaming edge. Gain the flexibility to choose from the 6 games modes offered—three factory preset game modes such as FPS, RTS and RPG and three customizable game modes you can personalize to your preferences. The dashboards displays the status of your key functions and pre-set modes so they’re easy track or change.
https://i.dell.com/is/image/DellCon...tor-aw3418dw-module-pdp-04b.jpg?fmt=png-alpha
Every seat is the best seat in the house.
The new swivel-hinge combo design supports tilt, swivel and height-adjustability so wherever you feel most comfortable, you’ll still have the best possible vantage point. It’s ultimate comfort for endless gameplay.
https://i.dell.com/is/image/DellCon...tor-aw3418dw-module-pdp-04c.jpg?fmt=png-alpha
Plug and play.
Multiple quick-access ports mean endless connectivity options and easy set-up, so your setup is just how you want it, wherever you want it.
https://i.dell.com/sites/imageconte...s-alienware-34-monitor-aw3418dw-module-05.jpp
Custom lighting effects
Enhance your gaming experience with AlienFX – a fully customizable RGB lighting system designed to bring you closer to the worlds you play in with dynamic lighting effects tied directly to the in-game action. Four customized lighting zones let you personalize your keyboard, monitor and mouse with different colors and effects to reflect your style. Create and download unique themes effortlessly for over 145 different games.
https://i.dell.com/is/image/DellCon...itor-aw3418dw-module-pdp-06.jpg?fmt=png-alpha
Connectivity Options
Ports:
1. Power cable connector | 2. Line-out port | 3. USB port with Power Charging | 4. Headphone jack | 5. USB 3.0 port | 6. USB upstream port | 7. (2x) USB 3.0 port | 8. HDMI port | 9. DisplayPort
Cables include:
1. DisplayPort cable | 2. Mini DisplayPort to DisplayPort cable | 3. USB 3.0 upstream cable | 4. Power cable
Dimensions & Weight
Height: 442.44mm ~ 560.89mm (17.42 inches ~ 22.08 inches) | Width: 813.45mm (32.03 inches) | Depth: 319.09mm (12.56 inches) | Weight (without stand - for VESA mount): 7.27kg (16.10 lb)
Tech Specs
Model number
AW3418DW
Viewable image size (diagonal)
86.7 cm (34.1 Inches)
Active display Area (H/V)
799.80 mm x 334.80 mm (31.41" x 13.18“)1920 x 1080
Maximum resolution & refresh rate
WQHD (3440 x 1440) @ 120Hz (overclocked)
NVIDIA features
Yes (NVIDIA G-SYNC™)
Aspect ratio
21:9
Pixel pitch
0.233 mm x 0.233 mm
Pixel per Inch (PPI)
109
Brightness (typical)
300 cd/m²
Color gamut(typical)
sRGB 99% color coverage
Color depth
16.77 Million colors
Contrast ratio(typical)
1000: 1
Panel Surface
Anti-glare with 3H hardness
Viewing Angle (H/V)
178° horizontal / 178° vertical
Response Time( typical)
4 ms (gray to gray)
Panel Technology
In-Plane-Switching
Backlight
LED edgelight system
Connectivity
DP1.2, HDMI1.4, 4xUSB3.0 + 1x upstream, Headphone Out, Audio Out
Game modes
Yes (FPS, RTS, RPG) plus 3 customization games modes
Stand
Height adjustable stand (130 mm), Tilt (-5° to 25°), Swivel (-20° to 20°)
Ultrathin bezel
Yes (~9.77mm Left/ Right, ~10.45mm Top, 18.43mm Bottom)
Flicker-free & Low-blue light
Yes (ComfortView)
AlienFX
4 customizable lighting zones, including1 downlight sensor
AC input / voltage / frequency / current
100 to 240 VAC / 50 or 60 Hz ± 3Hz / 1.8A (typical)
Power consumption( typical)
60W
Power saving(typical)
0.5W
Dimensions (with stand)
Height (extended ~compressed): 442.44 mm ~560.89 mm (17.42 inches~22.08 inches)
Width: 813.45 mm (32.03 inches)
Weight
Weight(without stand – for VESA mount): 7.27kg (16.10 lb)
Shipping weight: 18.51kg (40.81 lb)
What’s in the box
Components: Monitor, stand and cable cover
Cables: Power cable, 1 x DP cable, 1 x mDP-DP cable,1 x USB 3.0 upstream cable
Documentation: Drivers and documentation media, Quick setup guide and Safety Information
Warranty
3 years Advance Exchange Service & 3 Years Limited Hardware Warranty Premium Panel Guarantee
Looks interesting! TFT central have reviewed it. On the whole good aside from lower than expected contrast ratio which is a shame and brightness is borderline.
“Brightness is borderline”? What do you mean?
It’s $999 on sale direct from dell I believe at the mo so a reflection of what it probably should be priced at which is far better :)
Brightness comment was only from a youtube pundit!
Do you rate it above the 34a and PG848Q? I.e. is that contrast ratio defecit bad/noticeable?
I'd be happy if it matched the dollar price in pounds tbh
I'm not sure what that brightness comment could be in relation to to be honest, but hey. For gaming I think it's the best ultra wide available right now. The contrast is a little lower than the Acer and Asus models but nothing you'd really notice in real use. A VA ultra wide will offer you a better contrast ratio, but the response times generally aren't as good and the refresh is currently limited to 100Hz on 1440p models.
Good to know. I was really interested in the Z35P for the contrast level but worry about pixel transition time.
Oops sorry about hotlinking!
I know every panel is different but would your calibration settings get most monitors nearer to ideal gamma as it was 16-17% off wasn't it? I'm surprised as I thought Dell monitors we're legendary for being sweet out the box.
TFT Central have given this a good review, and given how this is from DELL I think should there be issues, one would at least have better customer service/warranty support...
Some mixed reviews on dell.com seems love or hate, possibly panel lottery two guys say the top border of the screen 0.5cm thick is dark and uneven colours is a theme also.
I hope either they lower prices to match the x34a/PG348Q or the Acer and Asus models drop in price.
Great spec! Doesn't look as nice as their standard ultrawide tho - which is sexy as hell. Why do manufactures think we want our gaming monitors to look like a Michael Bay transformer?
