Design me a window -
Don't cut up the ATC, sell it if you're not using it... they fetch enough for it to be worth while.
Anyway, I just got some bits \o/
Raikiri you thought about getting something laser cut into the panel?
Can have something better than a L-shaped window then. :)
Well, I'll leave it for a while. I might have the money in a few weeks.
That's a bit OTT for me, although the main tribal design is nice on its own.
I did file a bit with the dremel, someone's had my files though! (chances are I lost them... but meh).
I prefer using the edging anyway with the black case so you don't get silver on the edges.
I do actually have a set of etching pieces for the dremel so I might have a go, really depends on if I can find a design I like.
Fan edging will give you a gap to the window material.
Black permanent marker will cover up the silver cut edge.
Looks good Raikiri.
Here is what my finished window looks like if anyone is interested. ;)
Dragon and window - acrylic
Flames and other side panel also cut where hard drive lower part is - mesh
u should etch the window
they look great with a cathode behind
Sorry for bringing the thread back from the dead.
I actually had a quick go today at it, I think I'll buy the proper engraving dremel though... came out ok I think, looks better irl.
It's a Kanji ('Death').
