Guys
You need to be quicked, all backorders shipping and we literally have 100pc going spare, but we predice they will sell out within 24hrs:-
Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - Retail @ £269.99 inc VAT
Want to tune every aspect of your system for the ultimate in total system control. Then the new unlocked Intel Core processors which enable system tuning for the processor cores, memory, graphics, and power, were made for you. Whether you are a novice overclocker or a seasoned veteran, these processors will have you singing their praises in no time.
Looking for the perfect processor to build your gaming rig around? But you also want to edit your action videos and photos? But to do this you know you need serious performance. Not to worry - Intel is happy to announce our first 4GHz base frequency quad core processor. If it is performance you crave, then this is the processor you have been waiting for. But what if you feel the need to overclock your system to squeeze every last bit of performance out of it? Well, then this is still the perfect processor you. The lastest 4th gen Intel Core i5 and Intel Core i7 processors, paired with the latest Intel 9 Series H and Z chipsets, will get you the results you want. Add in features like built in visuals and Intel Quick Sync Video, which allows the conversion of media from one device to another and prepares your media from one device to another and prepares your media to share online at incredible speeds, and these are processors that meet every need you have.
The Intel Core processor family delivers a great PC experience. Whether you are looking for improved performance, greater adaptability, or differentiated visual features, Intel has the processor to fit your needs. Whether you use your PC for creativity, playing games, or everyday task such as homeworkd and email, these new processors make it easier to design, render, edit, play, and share.
Intel Core and for Intel Core i7 processors, Intel Hype-Threading Technology allows each processor core to work on two task at the same time, improving multitasking, speeding up the workflow, and accomplishing more in less time.
With 4th gen Intel Core processors, you can boot your PC, load applications, and resume from sleep nearly instantaneously thanks to Intel's responsiveness technologies such as Intel Smart Response Technology and Intel Rapid Start Technology.
The 4th gen Intel Core processor family offers hardware-level security that helps protect your devices, your data, and your online transactions.
The 4th gen Intel Core processor family automatically connects to wireless hotspots. Your email, social media, and apps are always updated thanks to Intel Smart Connect Technology. Finally, wirelessly stream your HD / 3D video and games to your TV or projector for presentations and entertainment using Intel Wireless Display Technology.
Features:-
- Improved thermal interface material (TIM)
- Updated packaging materials
- Supported by new Intel 9 series chipset
- Re-engineered for Enhanced Performance & Overclocking
Specification:-
- Lithography Process: 22 nm
- Cores: 4
- Threads: 8
- Frequency: 4.00 GHz (Turbo Mode 4.40GHz)
- Integrated HD 4600 Graphics
- Cache: 8 MB shared L3
- Memory Controller: Dual channel DDR3 1600/1866/2133/2400/2666+ MHz
- Socket: LGA1150
- Memory compatibility: All DDR3 1333MHz and above is compatible
- PSU compatibility: Check out our range of Haswell compatible PSU's - http://www.overclockers.co.uk/productlist.php?groupid=701&catid=123&subid=2597
- 3yr Warranty
Only £269.99 inc VAT.
ORDER NOW
Features:-
Specification:-
- Cores: 4
- Threads: 8
- Socket: LGA1150
- 3yr Warranty
ORDER NOW
