Devil's Canyon Z97 Build
Thanks guys. Yeah Neil. It seems I got a older batch chip but I'm very happy with temps. Did a slight oc to 4.5 without volts and its very cool. 4790k is very fast on stock:)
Must say Retro , that is one tidy sweet build there buddy. :D hats off to you mate. Love the co-ordination of colours and those cards fit in perfectly.
kudos.
That's a very nice build , I love those ASUS cards ... what kind of temps you getting on the top card ? I had 2 r9 270x 4gb card on air and the top card got up to 90 degrees , suppose I only had the fans set at 75% but anything above that and it was too noisy, so I moved the card into the 3rd PCI slot :)
Thanks, temps are very good actually. I've ran heaven for 2 hours and top card was 70c, bottom card 64c. It helps if you have a good airflow in your case.
Hmm, I am now torn between whether to get the same 2 760s that you have in your rig or go with a single 780ti.
I think they will offer roughly the same performance in 1440p gaming but the 760s have 4gb of video memory vs the 3gb on the Ti's.
I guess it boils down to whether the games I will play will want 4gb. I know watchdogs on the PC uses more than 3gb. Could be a continuing trend for future console ports?
£460 for SLI, roughly the same price as a single 780 Ti. What to do!!! :P
edit: Those ROG 760's do look the business though as well.
Yes mate. They look amazing and that was the main reason why I bought them. More for my theme and game play. They OC like beasts too.
I hear at 1440p with the 256bit bus hurts them a little, but I've played the new Tomb Raider at 1440p and it ran great. No issue. Just make sure you have good airflow in your case.
Great looking build there mate (:
Cheers Boom :)
Decent temps ! What do your fans get up to speed wise ? Since moving the bottom card neither of mine go above 60 degrees now , although having to rma one as fan has stopped working :( ...
