guest
guest
I don't run every thing on max but I like to keep the details fairly high and looking nice.?
There's your problem. The point of buying a 120Hz monitor is to be able to 'see' 120fps, and graphical settings be damned. It's for people who like maximum smoothness without going back in time to CRT technology.
Of course, it is possible to get 120fps on high settings if you've got enough GPU grunt, but such things cost money...
Absolutely disagree. Even at 60FPS a 120Hz panel is MILES smoother and more responsive than an IPS 60Hz.
I average ~80FPS on BF3 on my 120Hz and it is out of this world better than my (very) expensive IPS 60Hz panel.
...so I stand by my initial statement. If you're running 60fps on a 120Hz monitor, you're not even using half of your monitor's potential
That's completely correct of course. But 120fps on a 120Hz monitor is MANY MORE MILES smoother and responsive than 60fps on a 120Hz monitor...
From the other side if you're running a 60Hz monitor but your GPU is outputting > 60FPS you are not using the GPU full potential.
