HardlyYea you'll never have to visit a petrol station again, but you'll have the hassle of having to find and wait for (working) charging points. Great.
EV's have the opposite problem with brakes, the seldom use them and tyre wear increases with weight which is not just limited to EV. Car weights has increased over time regardless of propulsion method especially given the propensity towards the SUVHas the higher price of tyres/brakes etc been factored into your plans?![]()
Another point in favour of an EV - I took great pleasure in watching my **** neighbour outside in -3c this morning scraping ice off his car while mine was sat there quietly humming away defrosting itself![]()
Nah they have a special coating as they are EV, a few brake events are calibrated in much like brake drying and they will use friction brakes more when full battery naturally.
Why are sealed and greased caliper parts getting rusty enough to seize? Nasher could make stuff up, that is worse. I think your common sense has rusted up through lack of use too.
Coating for the non used bits obviously.
You still use the brakes in an EV… you just don’t use them anywhere near as much…. Literally the only difference is the disks and pads last longer. They still need to be maintained in the same way as brakes on an ICE car do.Special coating, lol. Any coating will vanish from the disks the second you use them.
Brakes seize up if they aren't used, they all do. In fact most moving parts do when outside.
I guess the tyres also have a special EV only coating? Let's not forget the magic EV only none-wearing out springs, bushes and bearing too![]()
Special coating for the non swept areas, which includes caliper pistons and carrier guides and a higher to resistance oxidation material selection for the actual disks. Feel free to join me on a call on Monday if you want to talk to a brake supplier and educate them?
It the way you calibrate out less of the forward moving disk 'clean sweep' events that exist to waste energy and just hurt range. Better material choice. Its just engineering pal.
Which is the same as any other good quality brakes. Nothing stops the British weather and salty water in the end.
What actually is the point you think you are trying to make?
