selling the car cos of a broken alt... LOL
I think he was referring to selling the "tuning" box.
I'd take a remap over a tuning box any day. As said above a tuning box ups the fuel rail pressure putting stress one expensive bits,
You'll get more out of a remap aswell!
Broken alternator at only 40k. LOL Vauxhall?
When the alternator in my Rover went that was apparantly LOL ROVER time as wellBecause Vauxhall are renown for making their own alternators aren't they? I mean it can't possibly be a Bosch, Nippon Denso or Delco item that's failed.
.Broken alternator at only 40k. LOL Vauxhall?
At least my Rover didn't break down and need me to literally kick it to get it started againTo be fair it's LOL ROVER time, all the time![]()
. In fact in the 4 years we have had it it didn't break down once
.At least my Rover didn't break down and need me to literally kick it to get it started again. In fact in the 4 years we have had it it didn't break down once
11yrs of Short Journeys and 80,000 miles isn't bad for a fuel pump to be honest. The car has never actually broken down, just needed a gentle bit of persuasion to get going once or twice
Have you owned the car 11 years??? How do you know it's been used for just short journeys??
And - if you have to ring up breakdown assistance then it is broken down.
Maybe, or maybe it was used for a less frequent number of long journeys? Or maybe a combination of short and long? Maybe you can't tell
Also how does the length of the journey impact on the fuel pump?
I stand corrected thenCome on, don't be silly. A 1.4 Fiesta is not a motorway cruiser. I can tell by the general wear and tear of the car that it has been doing short journeys for a long while. I have a MOTs which show the car has only been doing 4000 miles a year for the last few years. The last owner was female and used it to go shopping at to ferry her dog around which took me a good 6 hours of cleaning to remove all traces of![]()
I personally would make the assumption that mileage kills fuel pumps more frequently than short journeys.. But let's not argue eyLots of short journeys - lots of starts - Every time you turn the ignition, listen out for a little whirr, that is the fuel pump priming. I'm hopefully assuming correctly that lots of this will wear it out.
i argree with that, if you have a dual mass flywheel your clutch should be ok for a a lot more miles, pls dont use a tuining box they may **** up your sensors in the long run.
It's a fiat engine which produces 170bhp in an Alfa, and 180bhp in a Saab.
So 200bhp isn't such a mad state of tune. I don't know how the sport button would work though.
Edit:
Ah, this is a follow up.
YesThe 180bhp version in the Saab has two turbos
It's been bored by 1mm for an extra 46cc swept capacity.and the 170bhp in the Alfa is 2L rather than 1.9.
Yes
