difference between PSU's
Permabanned
26 Nov 2006
guildford, surrey
Check the figures/specs...
  • Hiper 730W: +12V=56A i.e. 672W/12 (here)
  • Corsair 620W: +12V=50A i.e. 600W/12 (here)
Though it might not seem, the Corsair is more efficient & can sustain a higher load. Basically its got a better build quality which, is by Seasonic :)
Also, Hipers reliability has not been very good the last few months (see here) :(
Question is, do you really need all that Watts?
The hiper will be noisier, have a shorter warranty, deliver less power where its needed most, won't last as long, may destroy components when it dies.
It probably won't deliver the power it says it can deliver either going by a review of earlier hiper units.
Its not a really bad psu mind, just at that price its a lot of money to pay for something which suffers from the problems mentioned above.
