There is a guide, It's in the cpu section on here,
all you need to worry about to start with is vcore (this is the cpu voltage setting) Bus speed (this is the clock speed your chip is running at) and multiplier (this is the multiplier which gives your final cpu clock speed)
As you have 32Gb of ram, I would guess all your ram slots are filled, so you would have an easier life clocking via the multiplier, instead of the bus.
What cooling have you got on your cpu? If stock, I would seriously recommend getting some better cooling first before trying this
