Mostly the hd-600s, played around with some others but it was mainly made for the 600s as everything else I own are below 300 ohm.
The bass on the 8066 isn't so much enhanced - its pretty neutral but seems to preserve "directionality" on low frequencies better than most other popular op amps which does wonders for the soundstage in general and perception of the bass.
2228 + 8066 for some reason has "thicker" bass and might not be entirely neutral to the source but very satisfying whereas when using the 4556 buffer it doesn't seem to "pass through" the deeper bass as much for some reason.
EDIT: Could also be the 4556 needs a little while to "burn in" I noticed 1-2 op amps seem to improve with a few dozen hours of use.
