But stockings for the win - So much better than tights![]()
Yeah I prefer stockings ............... I use fan filters on my pc though
Positive air pressure helps too - more air going in than out.
I'm about to cut my fans down to 2x120mm intake, 1x140mm exhaust. I'll be blocking up every other gap I can find in the case with magnetic strips (like the stuff you get on fridge magnets). That should mean that my intakes are dust-filter'd and air is blown out of every other orifice = less dust.
Why magnetic strips? Is it just because that's the easiest way to block them on a metal case or is your reasoning more scientific? Will you be using filters on your 2 12cm fans?
