ok so my new haswell mobo and cpu arrived yesterday, i just put it together this afternoon, all the other components are from my existing working signature rig
Gigabyte Z87N-WIFI and a i5-4670k assembled it with 8 gig of kingston hyperx from my i5-750, i assembled it outside of the case for a test run and nothing, the cpu fan spins up for a split second then stops, tried reseating the cpu, tried with 1 stick at a time of ram and still nothing, tried with only the cpu and ram installed but no luck, so i reassembled my old rig and all works fine again, so the reused components all check out fine, so im pretty sure its either the mobo or cpu. anything obvious i missed that I should try before i rma, or a way to figure out which of the two is at fault?
