Im starting to get a lot of nagging issues with my 4870X2 and im thinking of selling it and getting a Nvidia 295.
Or am i better waiting for something faster coming out from both camps ? whats the date on the next Nvidia or ATi
the current issues i have at the moment with ati are the following:
Blacks : watching High def its fine, watching ripped HD source shows or normal res dvds the blacks are blocky or have grey streaks though them very un,natural.
2d/3d bug : they fixed the issue in 9.1 and its back now in 9.2 but instead of the main GPU its the Slave GPU now.
Fan Profiles are broken : I have seen my card reach temps of 90c before i even notice that my fan is still running at its Idle 2d speeds, something iffy is going on as most of the time it works and speeds fan up accordingly but usual i get issues with it, if it was just random then fine but its doing it more and more.
Vsync issues : Vsync works perfectly when 1 monitor is connected, you try to connect a 2nd monitor and you end up with no vsync on the 2nd monitor, you unplug your main monitor and vsync magicly works on the monitor that didnt work.
there are lots of other issues that i dont like about ati
no gameing profiles.
no custom resolution support.
no fan profiles support
1 driver release per month ? i mean come on even if we get loads of betas its far better than 1 release that might just work 100% like its ment to, but that doesnt seem to be happing so i suggest they change there driver release scuedule...
i can go on and on, do i seem like im blowing all this out of porportion ? or do you guys think im in the right in saying the switch back to nvidia is worth it.
i want to hear your views becuse im not a happy camper with ATI at the moment, there driver team is like a team of monkeys on crack.
I bet you're a citizen of failsworth
