Do power supplies degrade?
On capacitors. They are specified to have a certain number of hours use at a given temperature.
High quality capacitors from the likes of Panasonic or Nichion will have figures like 2,000 hours @ 85*C. or 1,000 hours at 105*C.
Example:
http://uk.farnell.com/panasonic-ele...am102/cap-alu-elec-1000uf-100v-rad/dp/9693971
At lower temperatures they last longer, I'm not sure how linear the relationship is, but it is proportional. This is a valid argument for using an overrated power supply with will typically run cooler and thus the electrylitics will last longer.
The reason for the short life is simply that there is gel like liquid in Aluminium electrolytic capacitors. Even though the capacitor is fairly well sealed from the factory they do leak slowly overtime, the electrolytic effectively boils away until the capacitor fails, either short or open circuit, usually taking other things with it, sometimes dramatically.
Cheap capacitor are generally less well rated with lower life expectancy at a given temperature or a product might under spec the capacitors in terms of voltage or capacitor and the capacitor can self heat more and die younger.
There are new technologies that expand the life of aluminium capacitors such as "polymer" and "hybrid" capacitors.
AFAIK as a very rough guide you double the lifespan for every 10C lower operating temperature with some slight deviations from that being entirely linear - going from say 35C to 25C will probably make a little less difference than a 10C drop from Tmax and obviously depends a bit on the quality of the capacitor, etc. on average an aluminium electrolytic at the kind of temperatures in the average PSU/average operating conditions will last a little over 9 years - not to say it instantly fails then might just suffer increasing performance degradation for some time before failing properly.
Anyone here have any stories of power supplies failing? :D
In the early 2000's I was staying in digs whilst working away. I didn't have a PC there at the time but the house owner was cool and was happy to let me use his PC as he left it on all the time, usually downloading stuff (he had 2Mb broadband which was pretty fast for the time). Anyway one morning before heading off to work I was on his PC browsing, of all things PSUs for my own PC at home, when there was suddenly a bang, a smell and a dead PC. :( I had no time to have a proper look as I had to rush off to work but I picked up a PSU from a local computer shop on the way home and fitted it before the house owner got back. Thankfully all was well.
His old PSU, btw, had blown a rectifier to smithereens. It overheated because Chewbacca was hiding in the PSU fan and it stopped turning.
