Caporegime
- 18 Oct 2002
Who the **** do I have to fight to prove that Twisters are da best!!??? SHOW MEEEEEEEEEEEEEE!!!!!!!!!!!!!!!!!!!!
NGL,Who the **** do I have to fight to prove that Twisters are da best!!??? SHOW MEEEEEEEEEEEEEE!!!!!!!!!!!!!!!!!!!!
Honesly Rowntrees don't hold a candle to Calipos
IDK, but NV's had years of skimping out on the vram so they must have learned how to pack suitcases better.
For some reason AMD paired down the Infinity Cache size on Navi 32 and Navi 31. Plus Navi 33 still has the tiny Infinity Cache amount Navi 23 had. No doubt Nvidia has hogged most of the GDDR6X supply,but I do wonder whether having to use more MCD chiplets actually makes sense,over a larger die size.
I know they want to cut down on die sizes,but sometimes I really think they are going too far with this. If you have to use more MCD chiplets,more memory chips,bigger PCB,etc all adds to more complexity,power and cost.
@KompuKare sometimes talks about this too.
It's much faster, hence them needing less of it iirc.For some reason AMD paired down the Infinity Cache size on Navi 32 and Navi 31.
You can see why this guy a is a high school maths teacher and not a science teacher as he hasn't got a clue how to test something properly.
Looking forward to seeing your testing to debunk him!![]()
Why would I need to debunk him, if you can't see his testing methodology isn't at all scientific then the data gathered isn't useful.
If a job is worth doing it is worth doing properly, no?
The only problem I have with that specific comment is, the NV cards that I've owned 3070/80 that should have higher vram specs, they get gracefully rat faced drunk when it counts.I wouldn't have realised that nvidia handles the vram bottlenecks somewhat more gracefully than amd in certain games (not that that is a saving grace where 8gb is clearly not enough regardless)
Listen dude I didn't design the thing, go complain to Lisa Su!!!But in the end they are having to throw much more memory bandwidth this generation to increase performance.
Something called Delta compression in general and I think a new type of compression.Doesn't Nvidia use some sort of vram compression?
What people here seem to be missing is, compression leads to degradation in image quality.
I've always been vocal and tied this as the main reason why Nvidia image quality looked a bit softer then AMD when you swap out GPUs.
It's not, you have to turn it on but AMD and actually Intel looks sharper in general then Nvidia without that.AMD have sharpening turned on by default in their control panel iirc.
I own all 3 vendors
This, I currently use both AMD/Nv, increasing Digital vibrance in NvCP gets it closer to AMD.Nvidia image quality looked a bit softer then AMD when you swap out GPUs.
