At 30mpg for 7k miles a year, you don't stand to save a worthwhile amount
Good point, cheers anyways.
[TW]Fox;23671016 said:Fill the tank up. To the top. More than £20 this time, you drive an Audi, you can afford a full tank of fuel (And if you can't then why did you buy an Audi?). Then reset the odometer. Then drive until the light comes on.
Then fill the tank up again. To the top, again. Then note how many litres of fuel you've just bought. Use this together with the reading on the odometer to work out exactly what your mpg is.
Putting 20 quid in 'until the light comes on' is not going to give you an accurate consumption figure. It could be out by loads either way!
I filled it once and got around 370 miles if I remember correctly. (I got it when my job was good ha)
I'll keep you posted on my findings!
I get more than that in my 2.0T FSI A3 so it sounds pretty rubbish for a 1.6. Also, a 2007 A3 that doesn't show an MPG reading? I thought even base spec models would have a trip compuer![]()
A chap I work with drives a 1.3 Hyundai and puts about £30 a week in,
His logic being that having less weight in the tank will save him money from increased efficiency, he drives right past a petrol station every day though so he doesn't have to go out of his way to fill up.
