I'll add my other cards that I've used in recent memory
Evga 650 ti - yes
Gainward GTX 670 - yes
Inno3d iChill GTX 660 Ti - yes
Sapphire 7950 boost (reference 7970 pcb) - yes
Evga GTX 580 - yes
Asus directcuII gtx 660 - yes
Evga HD GTX 570 - yes
MSI GTX 570 reference - yes
Gigabyte GTX 570 reference - yes
Sapphire 6870 Flex - yes
EVGA 560 ti - yes
The 7950 was the worst of them all
Power supplies used - XFX Core 750w, Be Quiet Dark p10 650w, Be Quiet e9 400w, Corsair cx 400, FSP Aurum Gold 400w
Motherboards - Asus p8z68-lx, Asrock z77 extreme4, Asus p8z77-v, Asrock h77 pro4/mvp, Asrock b75m-itx
Evga 650 ti - yes
Evga GTX 580 - yes
EVGA 560 ti - yes
Evga 650 ti - yes
Evga GTX 580 - yes
EVGA 560 ti - yes
The 7950 was the worst of them all, even made noises in idle and when moving mouse.
I would suggest the OP is listening with a stethoscope and does not have what 99% of the percent of the population would call coil whine....or you know.......has tinitus.![]()
You've either got terrible luck, or something else is causing that whine....
I'll add to my list to offset yours...![]()
Club3d Radeon 9800 XT - No
Powercolour Radeon x850 XTPE - No
MSI Radeon HD3870 - No
Sapphire Radeon HD6950 - Yes
The sapphire HD6950 toxic did have quite severe coil whine. I solved that problem using clear nail varnish over the coils, now pretty much silent with slight noise on the credits screen at the end of unigine benchmarks. I also had a ground loop from the sound card to my amp which picked up bucket loads of noise from the gpu, like scrolling etc which caused chirping noises through my hifi. Isolation transformers cured that issue.
Other parts that make noise.
6 gentle typhoons @ 1000rpm, 1 enermax t.b silence 140 @ 1000rpm, 1 bequiet silentwings 140 @ 1000rpm, 1 XSPC D5 vario @ 5, 1 seagate barracuda, 2 western digital caviar SE.
