Hi Guys,
I was wondering if any resident electricians would be able to advise me on my situation.
I have a new build due to complete in October. Part of my desired upgrades inclued 33 downlighters throughout the house and 12 waterproof ones (6 in each) in the bathrooms.
The vomit inducing price to have them fitted by the developer comes out at £1650 for the regular downlights and £780 for the waterproof ones. A gob smacking £2430 for about 8-900 worth of materials. Price per unit works out at £50 per regular fitting and £65 per waterproof one (as shown in the upgrades handbook)
I popped on myhammer and have quotes from £1000 upto £1800 for supply and fit. My father used to work in the electrical wholesale business so I know that models & specifications of the downlights will vary grately (voltages, wattage, transformers etc etc)
I'm considering supplying the lights myself and just having someone come and install them and do the wiring however I haven't a clue where to start.
Whether I should be looking at LED? Or standard (halogen is it?) bulbs? There will be standard light fittings in most rooms except the bathrooms so the ones in the bathrooms will need to be reasonably bright to light the room. Also the sales rep said that each of the ones they supply come with their own individual transformer and are fire rates so I'm guessing I require this too so the NHBC will sign the warranty on the house? And it would also be eaiser to replace one unit with a small transformer than have to call a spark out to dig up one larger transformer for them all.
The developer won't be willing to allow me to send my own spark in there during the build to get in the way so the floor upstairs will need removing and then replacing (tongue & groove chipboard most likely, I've been told this might not go back down well?) and also loft insulation will need removing and replacing too with any necessary ventilation room for the lights.
I know I can get this done cheaper than the £2500 I'm being quoted by the developer I just feel a little bit clueless as to what it is I actually want!
What would you be recommending?
Any help would be greatly appreciated,
Thanks
BennyC
Thanks
BennyC
