Draytek Vigor 130 and FTTC SNR setting increased sync
I have noticed the new Vigor 166 appears to be on sale in the UK. It is only the Gen1 (so up to 330Mbps) but presumably is a lot better on the inside than the 130.
I believe a specific UK part was rolled out in December - V166-K - difference seems to be the preloaded firmware which is preset to work with Openreach G.Fast settings.
Some further information here:
https://forum.kitz.co.uk/index.php/topic,25203.30.html
Well. I have tried it on mine. No change yet.
I can only get 1/2 sync upload. Can anyone help me debug? I apply the 101 tag within the VDSL settings, (rather than on my Velop mesh router) - I think I am using the same settings as https://imgur.com/gallery/Xykm7Cf
Is there any way to edit the Cur SNR Margin to 3 DB?
Code:
  ---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
   Running Mode            :      17A       State                : SHOWTIME
   DS Actual Rate          : 66997000 bps   US Actual Rate       : 19999000 bps
   DS Attainable Rate      : 78358496 bps   US Attainable Rate   : 23652000 bps
   DS Path Mode            :        Fast    US Path Mode         :        Fast
   DS Interleave Depth     :        1       US Interleave Depth  :        1
   NE Current Attenuation  :       16 dB    Cur SNR Margin       :        6  dB
   DS actual PSD           :     6. 7 dB    US actual PSD        :    13. 9  dB
   NE CRC Count            :        0       FE CRC Count         :     1005
   NE ES Count             :        0       FE  ES Count         :      781
   Xdsl Reset Times        :        0       Xdsl Link  Times     :        2
   ITU Version[0]          : b5004946       ITU Version[1]       : 544e0000
   VDSL Firmware Version   : 05-07-06-0D-01-07   [with Vectoring support]
   Power Management Mode   : DSL_G997_PMS_L0
   Test Mode               : DISABLE
  -------------------------------- ATU-C Info ---------------------------------
   Far Current Attenuation :       18 dB    Far SNR Margin       :        8  dB
   CO ITU Version[0]       : b5004244       CO ITU Version[1]    : 434dc190
   DSLAM CHIPSET VENDOR    : < BDCM >
Yep, it's a mess at the moment.
Lots of reports of low sync speeds, particularly on VDSL lines.
The stats readouts are mostly dead (reading 0) making it hard to figure out problems.
Many of the CLI commands don't work (including SNR to tweak the target noise figure, it crashes the unit)
A new version, recently released in the EU & identified as GEN2, also suffers from the same problems (same firmware 4.1.1)
Thank you @ChrisD. had the modem set up yesterday and applied vdsl snr -30 and it has been stable with no increasing error counts but yesterday's actual rate was at 64Mbps but has now dropped to 56Mbps, do you know if it will increase in time?
Code:
   DS Actual Rate          : 56767000 bps   US Actual Rate       : 19032000 bps
   DS Attainable Rate      : 65831048 bps   US Attainable Rate   : 19064595 bps
   DS Path Mode            :  Interleave    US Path Mode         :        Fast
   DS Interleave Depth     :      827       US Interleave Depth  :        1
   NE Current Attenuation  :       16 dB    Cur SNR Margin       :        3  dB
   DS actual PSD           :     6. 7 dB    US actual PSD        :     6. 9  dB
   NE CRC Count            :        1       FE CRC Count         :     2477
   NE ES Count             :        1       FE  ES Count         :     2307
   Xdsl Reset Times        :        0       Xdsl Link  Times     :        4
   ITU Version[0]          : fe004452       ITU Version[1]       : 41590000
   Test Mode               : DISABLE
   Far Current Attenuation :       17 dB    Far SNR Margin       :        6  dB
   CO ITU Version[0]       : b5004946       CO ITU Version[1]    : 544eb206
   DSLAM CHIPSET VENDOR    : < IFTN >
