- 16 Nov 2011
I've been breathalysed after drinking 3 cans of 4%ish over 3 hours.
Breathalyser read zero.
If I'm just stopping in at the pub for 20 minutes then I won't drink, otherwise I might have a pint but certainly wouldn't have 2 and still drive unless it was going to be 3+ hours later.
Normally 2 pints over 3 hours or so.
From tests I have run, I am very confident I would not blow over the limit, or even a quarter of the limit.
I'll have a pint, used to have two but then a mate got pulled and taken to the station. He says he only had two and I have reason to believe him, by the time he was at the station he didn't fail. But obviously two can be enough to cause a load of hassle and aggravation, even if two pints of ****water doesn't even do anything!
Now as I usually want more than one drink and two pints is perhaps too much I'll have bottles instead. I'll make two bottles last as long as everyone else's two pints and that way there's zero risk. Not sure what it'd be like under the Scottish rules though.
You shouldn't be asking yourself "Am I under the limit", you should be asking yourself "Is my driving even slightly impaired". The limit is not there to cause the hassle of going down the station.
