- 17 May 2012
Okay installed a samsung 2tb and a WD ears 2tb into my pC and starting getting issues; pc freezing, freezing at "starting windows" for seven minutes, mouse lagging, BSOD once or twice. Found out by disabling the WD drive via device manager sorted it out; also noted the drive was "read only". Using disk park i got it to be normal so can read/write however after reboot it still took seven minutes at "starting windows". Also note it is visible in BIOS but NOT visible as on the list of drives in POST. It also took about five minutes to do a QUICK format. I am doing a full wipe with C Cleaner and a full format via windows to check if the resolves the issues. It as 100% health in HD sentential and passed the quick surface test
Is the drive failing? What else can i do and what program should i use to REALLY test the drive since i don't want to loose any data! (windows based programs would be best)
Thanks
Thanks
