I think it's a deluded post.This can't be a serious post?![]()
As above seems like one of those dash can warrior types that look to make problems.
So naive then. It really isn't going to make them think that, because I guarantee you that 99% of the time they will be jumping the red light because a) shaving a few seconds off their journey is more important than stopping at a red light, and b) they don't give a ****
Because your OP indicates that you believe you are responsible for policing the road and teaching other drivers a lesson.
So, how about if you were going say 50mph and they overtook at 60 (in an NSL)?
But by your own admission your using your horn incorrectly and risking a fine and points. But that's okay and the others isn't?If he indicated and moved over right in front of me, I don't care if he was driving at 100. I didn't have to brake and good luck to him, if he wants to take a gamble with a fine and points.
Don't forget the incorrect use of flashing main beams and hazards, those rules of the road are obviously ok to break.But by your own admission your using your horn incorrectly and risking a fine and points. But that's okay and the others isn't?
Oh yes they can, You haven't seen the dash cam videos on youtube. OP is probably a regular contributor to those channels.Definitely a wind up thread, no one can be this stupid.
You definitely come across as a passive aggressive driver.
I'd suggest less use of the horn.
Evening all.
I have some questions related to everyday driving. I am more interested to know what you do different than me or what you would do. These are all unofficial and I just wanted to sync my behaviour with what you all do.
Evening all.
1. Car ahead is driving slowly ( residential 2 way road ) > I sound horn quickly twice. If driver still does not increase speed, I will drive onto the other side of the road and overtake him by coming back to the correct side in front of him.
2. Drivers who go straight on a left only lane > 1 long horn
3. Drivers who cuts up everyone in a queue at a traffic light by driving down the wrong side > 1 horn
4. On a 3 lane dual carriageway, if I am on the right lane, and I am driving at the speed limit, if someone flashes me > Ignore and continue. On a motorway, if I do happen to find myself on the right lane, I will try to move to the middle lane as soon as it is safe to do so.
5. In a roundabout, if the car next to me is partially driving in my lane or about to drive in to me > 1 long horn
6. At a mini roundabout, if a car does not wait at the giveway line or drives in while I am going round > 1 long horn
7. Meet and greet situation in a residential road where it is a two-way road and cars are parked on both sides > If I am near the end of the road, I will reverse. If I am in the middle of the road or towards the front section of the road, I refuse to reverse all the way down the road , tell the other guy to reverse and switch off my engine.
8. If someone is driving at night with no headlights, use full beam and a long and loud horn
9. If someone is driving without headlights on a motorway, get in front of them and flash hazards a few times.
10. If on a motorway, there is traffic on the left and slow traffic in the middle lane but no one is in the right lane, and I move to the right lane and floor it. One of the daydreamers in the middle lane sees me and then comes behind me on the right lane and flashes me to move out of the way > Ignore him and keep going until I have gone past the slow traffic in the middle lane and can go back to the middle lane.
11. On a motorway, if someone comes in front of me at a car's length without indicating > 1 quick horn
12. On a dual carriageway, if someone comes in front regardless of distance > 1 horn
13. Anyone who jumps a red light > 1long horn
Evening all.
... and I just wanted to sync my behaviour with what you all do.
As above. The excerpt I've quoted from your OP suggests you may be open-minded. You've found out nobody behaves this way, so copy everyone here.You appear to be a horny driver.
How long ago did you pass? I'd follow the advice of other fellow OCUK members, time to take/retake test.
OP needs to watch a bit of Ogmios.
Spend more time learning how to park and less time correcting others when you struggle with the fundamentals yourself.Evening all.
