Dropped my laptop...
18 Oct 2002
and now the dvd rom extrudes slightly and when i push on it the laptop power cuts off. the dvd rom has power and you can open it etc but it isnt detected by windows.
the power cut off thing is worrying like.
any thoughts on whats wrong?
its probably just come adrift of the mainboard connector, theres usually one screw holding them in, just take it out and reseat it, at worst its damaged the mobo
i cant get it out. theres loads of screws in the bottom, ive taken out the ones i presumed were holding it in but nothing. or do i need to remove the whole of the bottom of the laptop?
If it's anything like my Dell you'll have to remove the screen, then the screws from the top (underneath the keyboard) before you can get the bottom off.
Hopefully would just be a simple case of reseating it, if the mobo is damaged then that'll be a nice price premium you can look forward to paying. :(
Not looking good, it'll either be an attempt at opening and reseating or an expensive bill from somebody who will do it for you (+any parts needed) :(
Alternatively leave it if it's all still working OK and buy a cheap external USB DVD...
well as long as i dont touch the dvd drive all is well. a slight knock and the power cuts though:(
It really isn't as bad to take laptop to bits as you'd think.
Repair bills for laptops are always tragically comic so I'm not sure what your options will be other than inspecting it yourself.
How old is the laptop? Might be better off just taking out the HD, flogging the memory etc and selling the laptop as a damaged unit. Even buying motherboards separately tends to be a hefty expense.
I tell people this all the time, you really really should never own a laptop without insurance tbh, all it takes is a simple fall and thats it, your laptops worthless,
anyhow, the best thing to do is take it apart, it's not as daunting as you may think, many people are scared to take their laptops apart which is why so many companies charge silly money for laptop repairs, as long as you take your time your be fine, with digital cameras being the norm these days you can take pictures of every step that you take so just in case your worried you may not remember how to put it back together again you can then use the pictures as a reference.
Here is a link to the HP website which has instructions and videos on how to replace the various components of your laptop. Just click on "optical drive" in the menu on the left to watch the video and get the instructions on how to remove it. Hope this helps.
http://h20181.www2.hp.com/plmconten...656&MEID=EF0F4F2A-0CFF-4EC2-A522-58229DBC1CB7
that is absolutely brilliant mate. thank you so much:cool:
look how easy it is as well:cool:
