DS WIFI problems
10 May 2004
Middlesex
DS WIFI problems + Lite questions
Hey guys,
I'm having problems connecting my DS to my router.
The DS is basically saying it can't find a wireless access point and I can't figure out why. (I've also tried configuring manually, putting in my ssid and wep key, also tried entering ip's, I usually use DHCP).
Its a Netgear 834g router (so should be compatible).
My laptop connects to it fine.
Any ideas?
Thanks.
*Edit. By the way, my DS is American. That shouldn't make a difference though should it?
Also my brother is thinking of buying a DS lite so we can play each other whilst in the van. You can get a ciggerette lighter lead for the DS. I've heard you need a step down converter for the Japanese lite, I take it this wont work with the lite?
Also will the Japanese lite connect ok to the American DS?
Surely the channels used for the UK and USA are differnt due to local regs, therefore in theroy they wouldnt work as the UK router would be on a different channel?
Or am i just completly wrong?!
I think it should be OK, 802.11b is an international standard.
Ardmanz said:
Sorry I meant 834g. I've edited my original post.
Still can't see it :confused:
I'm not sure channels have anything to do with it because these can be changed.
Whenever I install a WIFI card it does ask for the region and states things may not work properly if this is set incorrectly. So I'm thinking the region may have something to do with it.
I had problems getting it to work with the office router. It is a D-Link, a very similar model to mine at home, but the one in the office doesn't work, but at home it was perfect. Alas the DS's wifi stuff is not at all compatible with some routers. Most work, but plenty don't :(
But according to www.nintendowifi.com my router is supported!
punky_munky said:
Only thing left I can suggest is to try turning off WEP temporarily.
If all else fails you can by a Nintendo WiFi USB adapter. :)
I guess I may have to. Only problem is the computers is in my room and he often plays the DS when I'm asleep, don't like leaving the computer on because it keeps me awake. :)
I had the same problems with my DS connecting to a DG834G router. In the end i updated the firmware (V3.01.25) and bingo, it worked. I'm currenty running a Jap DS with my router settings being Europe/ Ch 11/ g & b
Haha, I just tried updating then came here and saw your post, worked. :)
Thanks for all the replies guys!
Could anyone answer the questions about the DS lite?
Thanks!
Glad you got it all sorted :)
I believe that the DS Lite has a different power socket to the older DS, so your ciggy lead won't work. I don't see why the Jap and US DS's won't connect (just don't blame me if they don't :p )
As far as I know, there is nothing stopping foreign DS's from connecting to eachother but if you are using games from different regions then you might run into difficulties.
Check in the shop as I haven't got round to buying mine yet but as far as I know the GB Micro uses the same charger as the DS lite now. You could well be fine with a GB Micro in-car charger.
Whoop
