DS3 Problem, help please.
17 Jan 2006
Scotland
Trying to get into bios in new build with no joy, I have tried 1 stick of ram and 2 in dual mode also have tried different cpu fans, also tried resetting the bios, using a friends Graphics card a ATI X300 I think, can it be the graphics cars thats at fault?
spec:
Crucial DDR2 BallistiX PC6400 2048MB CL4 ,Kit w/two BallistiX 1024MB's, E.P.P
Intel Core 2 Duo E6600 2.4GHz Socket LGA775
Corsair Powersupply 520W
If i read correctly you can't get into the BIOS?
This is an issue with some older gbyte boards. Unplug your hdd then try to get into BIOS again.
Update the BIOS when you next get a chance to fix it.
I have tried to get in with the hard disc unplug the hard disc, no joy!
phil14 said:
Do a mobo reset with the pins..
Phil, I bought the board second hand, I take it you are talking about the cmos pins, the pins are bare with no jumper is that the correct with the DS3? I am used to working with MSI boards where the pins are capped, I have tried capping them for a minute with the power supply off and then re-booting with no joy, maybe i'm missing something?
Use a jumper on the 2 pins, with the psu turned OFF. Leave the jumper on for 5 seconds, then remove it. When the speaker is connected u should hear one beep.
O.K guys found the problem thanks for all your help, it was the IDE channel that was causing the problem, i had 2 DVD drives wired up to the IDE slot, now I am getting into the Bios no problem, I thought it was probably the graphics card that was causing the problem!! what should I set the bios to, to avoid this problem again when booting, I will be using a sata 2 hard drive as my primary disc?
