- 7 Feb 2004
- North East
Thanks all. I've ordered the Asus card
- 2 x PCI Express 3.0 x16 Slots (PCIE1/PCIE3: single at x16 (PCIE1); dual at x16 (PCIE1) / x4 (PCIE3))*
- 1 x PCI Express 3.0 x1 Slot (Flexible PCIe)
- Supports AMD Quad CrossFireX™ and CrossFireX™
- 1 x M.2 Socket (Key E), supports type 2230 WiFi/BT PCIe WiFi module
*Supports NVMe SSD as boot disks
We'll soon see!
Hello,
With Intel desktop platforms, only boards with Intel Z-series chipset can bifurcate the 16 PCIe lanes connected to the CPU:
https://ark.intel.com/content/www/u...productIds=133348,189763,133284,125903,133293
And then only on motherboards that do not bifurcate to 2 or 3 slots already.
So for example here PCIe bifurcation is possible:
https://asrock.com/MB/Intel/Z390 Phantom Gaming-ITXac/index.asp
“Riser Card Support” option already available in BIOS.
With a custom BIOS version for example these models might also be able to support it:
https://asrock.com/MB/Intel/Z390M-ITXac/index.asp
https://asrock.com/MB/Intel/Z390M Pro4/index.asp
But this one not:
https://asrock.com/MB/Intel/Z390 Extreme4/index.asp
Because the lanes are split to x8/x8 already to connect 2 slots to the CPU.
And for example B365M Pro4 cannot support it either, because the chipset does not allow it. Same for all other B365/B360/H370/H310 motherboards.
Kind regards,
ASRock Support
I will take some blame for this - I assumed that because it had access to 8 lanes to could speak to two 4-lane drives without any issue, and it wasn't related to bifurcation in this situation. Apologies dude...
