Played this with a random online earlier and had great fun. It's definitely the best Quest native game in a long time. Really addictive. I'm up for a game tonight if anyone's on.
Probably my only criticism is the bow drawing mechanic is a bit iffy. Often you'll get the haptic feedback saying you've grabbed an arrow, but none is drawn. Frustrating.
The aim assist with throwing weapons is strong! The dagger is a bit smaller so seems to get deflected a bit less.throwing axes is probably my fav so far
when i did the tutorial , i was getting a lot of bullseyes with it, then i took out the bow, and i missed a lot ! lol
both shi and I struggled to get off the climbClimbing is ok, you need to use the quick climb option.
There's a great rush when you find new gear and again when you see the stats.
I've had one instance where it wouldn't let me teleport off with the thumb stick. That was irritating. I just sort of threw myself off.both shi and I struggled to get off the climb![]()
Does DoE have a lobby so you can pick up randoms to play with, or does it have to be existing friends?
Thanks.. it does seem a step closer to dungeons and Dragons VR, but not quite there yet...You can quick join any game, create an open lobby or even a friends only one.
