- 26 Sep 2006
- West Bridgford
Thanks guys, much appreciated
Thanks Richdog, and what a good idea! Q2160, 256kB cache per core, I'd buy one![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
Are you sure it's your CPU dying? One solution would be to overclock cheap CPUs, but change them every 6-12 months. I didn't lose much on buying then selling my e2160, another good reason to get the cheaper CPUs, as they depreciate less.
Richdog said:Great review old chap, makes you wonder if they're going to do the same cache-cutting magic with the Quads too..![]()
Pkiely said:Nice thread.
My last build has started to die prematurely I'm certain because of having my cpu overclocked too far, decreasing it's life span. My next build I don't fancy overclocking so I can keep it for as long as possible, 3 years+ maybe, so your concept I should probably keep away from? Or does intel chip's keep a good life expectancy on stable overclocks ?
