I don't have the figures for the clearances for those VAC bearings, but they were
stated as being the latter extra clearance ones. Those bearings are still available, although the VAC's store website gave no useful information on that!
As for the oil pressure, another factor for oil flow for the oil wedge is clearance, if insufficient it won't allow enough oil flow for the oil wedge to be effective. Agreed cold oil will make that worse.
RE the S65's BMEP, IIRC that essentially means the power of each combustion event (I only remember for sure that it stands for Brake Mean Effective Pressure
), so more related to torque output? I know it's relatively low compared to a turbo diesel or turbo/SC petrol engine, but I wouldn't describe it as low, anyway, semantics
As for BE's oil flow test, I'm not sure which part you are referring to mentioning increased oil pressure with BE bearings, I can only guess you mean a not insignificant amount (so ignoring a few PSI variations here and there), so increased pressure IIRC was only significant at startup, for 1st ~2s. The oil pressure increased to operating pressures more quickly due to the higher flow of oil due to the bigger clearances, the oil got to the sensor (and bearings) faster, and the variable flow/pressure oil pump was mostly able to make up the pressure despite the extra oil losses, see
here (I'm baffled too as to why they didn't realise that! lol I'm sure they say somewhere else that's why). So it's not higher oil pressure overall, but it gets up to (sometimes very slightly lower) pressure faster. If you're not referring to that then you'll have to be more specific.
People say 10w/60 is too thick because of the tight clearances that the S65s have, it's the combination that's the problem.
As for the extra power lost due to higher flow rate, that's going to be a tiny amount, if any at all, as that will be countered somewhat by having less resistance to pump it out in the 1st place. I'd imagine the 2 would near enough cancel out?
Afraid you're point about using tight clearances with thick oil to reduce power losses isn't right, thicker oil uses more power to pump (and causes more drag), most modern engine use 0w/20 (or thinner!) or 5w/30 with tight clearances, they have to be tight for the thinner oil, the thinner oil reduces power losses and improves MPG. Too thick an oil through too tight clearances will cause oil starvation.
Interesting about 10w/60 being nearer a 7.5w (I tried to convert the 40C kinematic viscosity of it to a 'w' rating but was unable to find an appropriate chart), that probably explains why people using 5w/50 tentatively don't seem to fair much better (although their is precious little data for that). It would imply that 0w/40 ought to be used, but then you have the problem that the 40 might not be thick enough for high temp high load scenarios! (although some people do use 0w/40, more in cold countries, IIRC).
I never directly referenced an old 1980s clevite bearing,and I doubt BE would, where did you see that? The files I referenced are of this century at least!
(my Mahle one is from 2014, they own Clevite now).
There is a design flaw, it's clearly there in the clearance numbers, but even if you ignore that, the photos of pulled bearings says it all.
Of the 266 cases with good enough photos I have looked at (and have linked in my data file, I can post it here if you like, I haven't yet as I'm still adding to it), 250 of them are excessively worn, 105 of those are critically worn (only a few are down to debris scoring the shells), i.e they are nearly all the lead/copper type which are
showing copper (once copper is visible they could suffer imminent failure, as per the pdfs I linked earlier). Only 12 are moderately worn, and you could argue they are ok, and just 4 are in the good condition which they should be! Of which, 1 of those is the VAC bearings I posted above, and another one was suspected of being non OEM bearings.
So that's 94% of the shells pulled are in a bad way, even if you dismissed the ones which are not critically worn, the remaining 105 account for 39.5% of pulled bearings.
Although it appears as if the LCI bearings fare somewhat better, the trouble with those bearings is that when the embedded layer is worn through on those to copper (it turns out the tin/alu LCI bearings do have a very
thin copper layer), it doesn't stand out like it does on the lead/copper ones. I think I have a few photos with LCI bearings giving a slightly goldish colour, which I think means it's worn through the embedding (babbitt) layer, but it really isn't certain, so they're not off the hook either unfortunately.
So all we can say with a good degree of certainty is that a very high proportion of shells are excessively worn.
Are they
ALL imminently about to fail? Probably not, but unless you know they've already been changed, you don't know which end of the spectrum your engine lies, nor how much life is left in your bearings.
In addition to that, we
can't rely on oil analysis to catch it, it sometimes misses it, either due to tests not being done from the start &/or it not covering the size of particles produced by failing bearings, oh and it can't monitor the tin/alu bearings either.
Anyway, my car's a 2008 model with 75k miles, when I found out earlier in the year that oil analysis is of limited use for bearing monitoring I garaged it, I had planned to change the bearings in April/May but the lockdown hit, and finding measured non BE shells is easier said than done, although I think I have finally found another person who has!
(incase you're wondering why I haven't bought BE bearings, it's because they're 3x the cost of ACL ones!! Even allowing for their research that's too much!
