UK? who said UK
How do you know I didnt take it to autobhan or I know a privately owned road?
No worries
UK? who said UK
no idea what they will say but im not paying for vw parts.. £400 just for front Discs and pads when i can get them for £200 :sIve just changed the oil/filter 4x Discs and pads on my Toureg, just about to drop it off at VW for a Service and tell them the above is doneno idea what they will say but im not paying for vw parts.. £400 just for front Discs and pads when i can get them for £200 :s
[TW]Fox;24050240 said:I doubt discs/pads have any space in the service book so no big deal.
Though quite why you'd take your car to VW for a service having already changed the oil is beyond me, what a strange thing to do![]()
Popcorn at the ready![]()
Yeh exactley I would never go to a main dealer for brakes
You can affrd your toureg I can afford my M5 but we are not stupid enough t get ripped by these dealers
Just so they can (check) the car over for little faults, also the main drive shaft to rear was changed under VW so needs checking again, that was 1k to replace but has warranty with the main VW garage..
I do not know why the OP ever posts on here as he always 'seems' to just get ripped apart, justified or not.
I can only assume that he is feeding the usual trolls their weekly dues.
I'm sure a little Google search would have come up with the answer in the first instance or a call to a BMW dealers parts dept.
One thing to note 12k car resale <12k is going to fall into the hands of another barrel scratching punter who isn't going to give two hoots whether one car has a spark plug stamp versus one that would fall above this price bracket that has.
OP all I can say is keep the receipts for any work that you do so it's all documented so you can show what work you have undertook within certain home aptitude levels e.g. oils, brakes, filters etc that personally would rather I was not ripped off by dealer pricing if I was able to do the same job using genuine OEM parts.
[TW]Fox;24050097 said:BMW's with Condition Based Servicing will tell you on iDrive when certain parts are due replacement. Presumably iDrive is now saying renew Spark Plugs.
That price for sparkies is fine, stop being a tight ass and owning / running a car you actually can't afford to maintain.
